Fehler in der Wiedergabe
  • Wollte das Hobby Forum öffnen und dann kommt diese Meldung.
    Es scheint ja wieder zu funktionieren :)
    An error has occurred
    Internal error code: 9dec0ed4d130fc2b6f5cdda229a3f9c82a249509
    What happened?
    An error has occured while trying to handle your request and execution has been terminated. Please forward the above error code to the site administrator.
    The error code can be used by an administrator to lookup the full error message in the Administration Control Panel via “Logs » Errors”. In addition the error has been written to the log file located at */log/2026-08-19.txt and can be accessed with an FTP program or similar.
    Notice: The error code was randomly generated and has no use beyond looking up the full message.
    System Information
    • PHP Version:
      8.1.34
    • WoltLab Suite Core:
      5.5.26
    • Peak Memory Usage:
      0.418/256 MiB
    • Request URI:
      GET /user/5001-steuermann/
    • Referrer:
      RE: CP La Plage - Lac de Robertville, Belgien
    • User Agent:
      Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) SamsungBrowser/30.0 Chrome/143.0.0.0 Safari/537.36
    Original Error
    • Error Type:
      PDOException
    • Error Message:
      SQLSTATE[HY000] [1040] Too many connections
    • Error Code:
      1040
    • File:
      */lib/system/database/MySQLDatabase.class.php (50)
    • Stack Trace:
      • #0 */lib/system/database/MySQLDatabase.class.php (50):
      • PDO->__construct()
      • #1 */lib/system/database/Database.class.php (142):
      • wcf\system\database\MySQLDatabase->connect()
      • #2 */lib/system/WCF.class.php (357):
      • wcf\system\database\Database->__construct()
      • #3 */lib/system/WCF.class.php (178):
      • wcf\system\WCF->initDB()
      • #4 */global.php (15):
      • wcf\system\WCF->__construct()
      • #5 */index.php (10):
      • require_once('*/global.php')
    Final Error
    • Error Type:
      wcf\system\database\exception\DatabaseException
    • Error Message:
      Connecting to MySQL server 'localhost' failed
    • Error Code:
      1040
    • File:
      */lib/system/database/MySQLDatabase.class.php (67)
    • Stack Trace:
      • #0 */lib/system/database/Database.class.php (142):
      • #1 */lib/system/WCF.class.php (357):
      • #2 */lib/system/WCF.class.php (178):
      • #3 */global.php (15):
      • #4 */index.php (10):
    Grüße aus Europa
    Evelyn und Gregor
